Go to solution Solved
S24 ultra battery draining 3 to 4 % in 1 hour without using any apps
(Topic created on: 17-03-2024 08:11 AM)
Ashique 95
Hai guys
Anyone experience draining the battery when the phone is not on use . Every hour the battery draining 3 to 4 % someone knows how to fix the issue. When I check the battery usage history there is showing no apps are used I will upload the screen shot below pls help me guys to fix the issue  (my screen on time is 7 hours without disable any battery consumption settings tell me about yours?
Go to solution
14 REPLIES 14
Piper123
Samsung Members Star ★★
Doesn't make it better
I am not employed by Samsung nor do I receive any remuneration as a Samsung Members Star.
My device is an S25 Ultra.
Ashique 95
Will this do by pressing volume down and power button ?
Glenntech
Samsung Members Star ★★★
Wiping the Partition Cashe clears out a lot of old or corrupted information that can cause issues
Follow the steps below. You must follow every step and you should be done in about a minute
Turn off your phone.
Connect your phone with a USB cable
to PC or another Samsung mobile
You will see the charging icon on your screen.
Wait till it shows charging with battery percentage.
Next, press and hold the Volume up and Side key simultaneously.
You can press the volume up button just before the Side key.
The Samsung Logo followed by
Samsung Galaxy appears on the
screen.
At this point, release the keys
Phone will boot into Android Recovery mode
In Android recovery mode, using Volume keys, choose "Wipe Cache
Partition" .
Use the power button to accept that.
You will then see its cleared.
Then the top option, reboot phone.
Press the power button to reboot the phone and then sign in normally
Nakuro
More than 1% when idle is far form normal.
Outpost43
I have been experiencing a similar issue with my Samsung Galaxy S24.
The phone gets hot without apparent reason, I make sure all the apps are closed, I see low CPU usage (via DevCheck app), I disable the mobile data (= no Internet) and the temperature still stays high while the battery drains fast (checked via DevCheck app).
I haven't found any workaround but switching off/on the SIM cards temporarily or turning airplane mode on/off.
I wiped the cache partition but am still having the same problem.
There is a bigger thread about this issue, with many views and multiple replies.
Products mentioned in this post
