Go to solution Solved
Help! Device control and settings have gone.
(Topic created on: 14-05-2025 10:46 AM)
MarkPainter
Hi Folks.
Just had an update from Samsung and everything has gone from the screen when I swipe down.
The settings and Device control are no longer there.
All I get now is a message saying no notifications.
How to do I put it back as it was before so I can get to my settings, control my devices and turn on Wifi / bluetooth / torch etc?
In addition there's a icon saying +32 which does nothing when I touch it.
GoanGeek
Samsung Members Star ★★
Hi and Welcome.
Pull down the Notification panel two times
Click the pencil icon > panel settings > Device and control media buttons.
Happy Days.
Follow Me, like my posts and Mark as Solution if I helped solve your Problems.
5 REPLIES 5
GoanGeek
Hi and Welcome.
Happy Days.
Moiramon
Swipe down then click the pen icon at the top. Then click panel settings then select together and it will be back to how it was in one ui 6. Currently if you swipe down from the right you get the settings and swipe down from the left is notifications.1747218377557.jpg
johnz237
Woodyam31
I am unhappy, my favorites have disappeared in my phone list since I downloaded the update this morning, how do I get them back.
angelus8756
Drag down from far right (wifi bar/batt%) and you get the old stuff, bluetooth etc 👏
