Battery problem after update
(Topic created on: 05-11-2024 01:37 PM)
Ady96
Hi. Is something happening with my battery after last updated. I buy my s24 ultra in August, and after the last update, my battery *****, because in 4 hours I lost 40% , but I didn't use my phone.
6 REPLIES 6
Tourbillon De La Vie
Samsung Members Star ★★
BandOfBrothers
Hi @Ady96
Have a look in your Device Care Section under Battery to see what apps are using your battery.
https://www.samsung.com/uk/support/mobile-devices/tips-to-make-the-most-out-of-your-galaxy-phones-ba...
If i can be of any further help please don't hesitate to ask  😎
Daily Driver > Samsung Galaxy s²⁵ Ultra 512Gb ~ Titanium Black.
I'm here to help. " This is the way. "
Laurac84
Voyager
Have you updated too the latest software? After the last update my phone was the same but since this update that's just out it seems to be back too normal.
Merlins23ultra
Navigator
Jic, I recently had a similar problem,and what I found was that I probably had too many widgets active. After removing them all and observing the phone over 24 hours, battery life was noticeable better.ive slowly started introducing them back, only this time I'm more selective about what I actually needed rather than looks good 😂
I was lucky. Previously, problems I've had have only been rectified by a full factory reset,which is not so bad as long as your backups are current.
Good luck
I have the same problem with this update.  Went from being able to have 11hrs plus of  screen time. To no more than 5hrs. Done all the usual wipe cache etc etc. I can't even figure this out. Never before coming from s2 s7 egde s9plus note10 plus best phone ever! The s23 ultra never had an issue with updates but now with the s24 ultra last weeks update seems to have screwed it a little?
Regards
Eric
Vishnu prasad
I'm still having that same problem since April's update.
