Battery draining issue
(Topic created on: 08-02-2025 12:19 PM)
S-Kills
Hi,
My Samsung Galaxy S24 Ultra phone was working fine for 7 months. But, suddenly for the past 1 week or so it's battery is draining very fast. Is someone else facing this issue and what could be the cause and solution for this?
8 REPLIES 8
Star_girl
Samsung Members Star ★
My phone is doing this sometimes but it fixes itself and battery life is good again.
rogersdave77
Troubleshooter
Do you clear phones cache partition after updates?
S-Kills
No, I dont know how to do it. Can you tell me?
GoanGeek
Hi.
Software updates can sometimes mess up the battery for a few.
Key is to make sure you keep checking for app updates in both Samsung and Google stores.
Also sync errors or Bluetooth off if you have other accessories attached can cause battery drain.
Follow Me, like my posts and Mark as Solution if I helped solve your Problems.
lminvti
Hi @S-Kills and warm welcome 👋
Try wipe cache partition.
Turn off your phone Plug to PC, tv etc via USB Then press and hold power and volume up button until samsung logo appears Then quickly release power button and keep holding volume up button until reboot menu appears then navigate with volume down button till wipe cache partition press power button to confirm restart your phone.
Check apps and see which ones drains battery most try to reinstall them.
Batterystats reset:
Turn off autoblocker
Open phones dialer
Type *#9900#
Scroll down until you see batterystats reset press on it.1739020245227.jpg1739020245251.jpg
S-Kills
Thankyou so much!!👏 This is really helpful
Piper123
1. Turn off the device.
2. Connect To Computer USBC to USBC (you may also connect to another Samsung mobile via USBC). Press and hold the Volume Up key and then press and hold the Power key
3. When the Android logo displays, release both keys.
4. Wait until the Android system recovery menu options appear.
5. Press the Volume down key several times to highlight wipe cache partition.
6. Press Power key to select.
7. Press the Volume down key to highlight yes, them and press the Power key to select.
8. When the wipe cache partition is complete, Reboot system now is highlighted.
9. Press the Power key to restart the device.
S24 Ultra
lminvti
Not a problem, hope it helps.
