S23 battery drain following One UI 7 update
(Topic created on: Saturday)
jamesefc1991
Navigator
Battery seems to going quite fast on this new update compared to oui6 any solutions I dont..want to do a factory reset and lose everything
116 REPLIES 116
jamesefc1991
Navigator
Well what if it doesn't im sure Samsung will sort it out as they will need to do something about.just seen that's what people have been doing and it works or doing that cache,but il just wait and see what happens...
Joeeye
GrandMaster
It's warmer weather, naturally battery life is reduced.
johnz237
Legend
Very good point
UK1989IT
I have been having the same issue since the past two software updates, so, it started a few months ago and still has the same issues despite no new software update.
I have to charge my phone 3 times a day full and goes down to 1% so rapidly like I have never seen any phone go down before since there are mobile phones...
I loved this phone the first half year its battery lasted for two full days. And now it empties within a few hours without any heavy usage nor any background apps and low brightness and no always on display mode etc and even on battery saver mode.
dillydarlin
That does not make any sense. Why would my battery drain super fast and then it take two weeks for it to learn my battery cycle? I used to only have to charge my phone once a day and if I didn't use it at all it could stay charged for 2 days literally after updating it has dropped 20% and only 4 minutes and it keeps reopening all of my apps
Ravs88
As with most, after the one ui 7 update, my battery life is shocking. It's pointless having a phone like this when you have to constantly keep an eye on the battery, also switching functionality off just makes you think what's the point of having the phone. Will Samsung listen and actually fix the issue? I've reported it as a an error as some forums suggest.
I've done the whole wipe cache partition and given it a few days for the battery to calibrate.
johnz237
Legend
The battery can take 14 days to calibrate. Its good that you've also reported it....hopefully it improved by its self
Tourbillon De La Vie
Samsung Members Star ★
What's the issue. How long did the battery last before and how long now? Maybe a screenshot of your battery usage. How old is the phone
rogersdave77
Troubleshooter
Did you wipe the partition cache after installation?
Piper123
If your battery is weaker, it will be because of a rogue app causing drain.......
You will need to look at your apps and see which is using the battery.
Also note the comments above about battery synchronisation 14 days
S24 Ultra
