a month ago
I'm trying to install an APK, so I need to enable installation from unknown sources in the settings. However, every time I do this, the Settings app crashes.
Does anyone know how to solve this. I don't want to reset my phone
Solved! Go to Solution.
a month ago
Solution Found!
I had a work account that was set up before the One UI 7 update. I removed it today to install an APK file, but it wasn’t completely removed — remnants of the company policy were still in place. To fix this, I reinstalled the work profile using the Company Portal app and then removed it again. After doing this, I was finally able to access "Unknown Sources" and install APK files without any issues.
Maybe Samsung can have a look in to this bug.
a month ago
Hard reboot the phone and try again
a month ago
Already dit this ..twice
a month ago - last edited a month ago
this is what happens
a month ago
Troubleshooting steps taken:
-Hard Reboot
-Killed all open apps
-Cleared Cache/Storage on settings
Nothing helped
a month ago
Does it work in safe mode
https://www.samsung.com/uk/support/mobile-devices/how-to-start-my-galaxy-device-in-safe-mode/
Just checked, it does the same thing in safe mode
a month ago
Did you customise your phone and remove some apps via adb? Maybe disable auto blocker if enabled
Run diagnostics via Samsung members app
a month ago
Solution Found!
a month ago
