S23 Battery drain fast when idle
(Topic created on: 19-06-2024 01:39 PM)
Good luck to me
Hi,
I've had this phone (regular S23) for about 6 months now(I was very happy with the battery life) but about 2 months or so ago the battery life dramatically reduced.
But since then, probably some UI update, my battery will drain from 30% to 0% in very little time even with no use.
This evening it dropped 32% with 15 minutes of screen time (over about 4 hours, used more power than it did in any 4 hour period for the rest of the day, even when I used the phone for more than 90 minutes). I do have wifi on, bluetooth ect, but this was never an issue until recently.
Also, it never does these types of drops at high charge levels, like it never drops to 70% from 100%.
Finally, my phone usage behavior hasnt changed at all over the past 2 months. In fact, my old Galaxy (4 years old now) lasts longer than this one.
Why?
Thanks
4 REPLIES 4
PenGossiper
Voyager
Check your settings, most especially your frame rate
Micael-1
Eloo
Just to say same problem here with s23 Ultra. I hope samsung is fixing this fast because this is real bs!! I have to charge 2 times a day
Vanfeder
Same here. Interestingly this never occurs at higher battery charging levels. But when it falls below 50%, then it can go straight downwards anytime.
