Battery drain
(Topic created on: 08-10-2025 07:43 PM)
K25WDE
Anyone else experiencing rapid battery drainage when phone gets to about 40%
Every since the September update my battery has started ti drain significantly when battery reaches about 40%, I was hoping the recent October update would cure this but yet to see any change. Im only using the phone 20 minutes in my lunch break and leaving work after a 8hr shift and its down to around 40% with hardly any use and only using WiFi
Is there a fix for this?
22 REPLIES 22
Tourbillon De La Vie
Samsung Members Star ★★
What is the screen on time
SlimFan
Voyager
i tried all the fixes everyone says but they havent worked for me
my battery life is actually so bad it's insane, just scrolling on Spotify, i went from 15 percent to 13percent in about 1 minute and a half
K25WDE
Is that the screen time out time?
K25WDE
It's so frustrating, I go from 22% lock my phone pop down to the shop which is a 3 minutes drive and when I park up and get my phone out its down to 12% then dies
K25WDE
SlimFan
Voyager
yeaah, this is a huuge problem and ngl, i feel like samsung isnt rly doin anything which isnt great considerring I'm thinking of buying the base iphone17, cos i have an s24U and i went to an apple shop, and broo the BASE IPHONE had a better selfie camera, main camera and ultrawide than my "flagship" phone, still, losing 2 telephotos will defo be rough
4hrs sot for a 3 year old battery is good
K25WDE
It's just unpredictable, I have to now use powersave mode to prolong the battery's duration you can see on the graph the drastic drops in the battery... ive just had a weird issue happen
Phone was on 23% percent i turned it off then back on and showed 0% plugged my charger in and it jumped right up to 22% so turned it off again and on and done the same thing so put charger back on at 10% and it just counted down to 0% very fast and then died
It's so strange its ever since the last 2 updates
K25WDE
It's a very frustrating issue and samsung need to do something about it
I've done all the battery checks and it's coming back good health so can't be the battery it must be the software
Even though the Samsung s23 has a 200mps camera its no where near as nice as the iphones for some reason, they just seem to focus alot better and the screen seems alot better but I dont think I can ever go back to a iPhone 😅
