Bluetooth connection problems
(Topic created on: 16-01-2024 01:01 PM)
Kayepunch
I have an S23 and after the November software update the phone does not connect to my car's BT for music and voice. I was hoping the latest update (Jan '24) would sort it out but it hasn't. I have gone through all the steps repeatedly, reset the phone to factory, and had the data sent to Samsung tech dpt hoping they'd find a solution. Nothing has worked. Anybody else experience a similar issue?
33 REPLIES 33
Lang_ley
I've been experiencing the same issues. I cannot connect to any Bluetooth device whatsoever. Now all because of the latest update and it used to work but now it does not and I don't know why and I'm about ready to just switched back to a d*** iPhone because at least I know it works even though there are apple service fees for everything and it's stupid.  You're always stuck with something going on.Regardless.It's like you might as well throw the darn things away!!
fc7111
Hi have an S23 Ultra and I have been having a problem with bluetooth headphones not allowing left and right to be connected bought new ones and same reset bluetooth and headphones and still won't connect as a pair
Hoffy One
I had the same problem with my S23+ after the big update. I tried all the other recommended solutions, but resetting the Bluetooth setting on the phone seemed to fix the issue. Go to: Settings > General Management > Reset > Reset Wi-Fi and Bluetooth Settings > Reset Settings. You're going to have to reconnect to all your Wi-Fi and Bluetooth devices afterwards, but my phone connects to my car without any problems now.
dyver83
I have an Ultra 23 which would not pair with a ***** radio.  My default AVRCP was 1.5, lowering it to 1.4 worked!  Thanks for the great information.
Blairruff1
S21 ultra and having same issue since I got the phone a few months ago
Blairruff1
Did both of these and nothing worked
Members_iLaFuC2
Hi.you can install Bluetooth - Auto Connect app frome google play store.and connect your car with this app.after connection you can uninstall it
adstony
Sense last weeks update on my s21 ultra I cannot stay connected to any Bluetooth devices.  I have done every fix and I can connect to most of them once then after that it stops working again. I connect USB to android auto and then keep getting failed to connect to Bluetooth.
adstony
I have tried this but my phone does not have the clear cache for Bluetooth.  The latest software update is what messed my Bluetooth up.
