14-03-2024 03:20 PM
- Mute
- Highlight
14-03-2024 04:30 PM
- Mute
- Highlight
You might also want to look at screen brightness, Always on display and other items that might reduce the battery.
You should be able to use the phone in its default state, but sometimes you need to do some maintenance to ensure there aren't any apps running in the background and draining on your battery.
Smiley.
User: Smiley
If my reply has been useful in resolving your issues, then please like and 'mark as solution'.
My life is full of positives and negatives. I’m an electrical engineer.
14-03-2024 04:38 PM
- Mute
- Highlight
Have you got a rogue app in the background constantly trying to sync like Google photos? More information would make it easier to explain, also how long have you had the phone?
14-03-2024 04:52 PM
- Mute
- Highlight
Like you can see mainly used YouTube, and other app amd snapchat for 30 mins.
I keep brightens around 50%.
Main use WiFi throughout the day.
But if you compare to an iPhone 12 Pro max which my friend uses he listen to music for more than 4hrs a day with Bluetooth but still have 30% left at 10pm night with 1 charge.
Why does a phone have 5000mah battery if it can't run without using data for long period of time
14-03-2024 05:02 PM
- Mute
- Highlight
When you check what apps are using the most battery you can click on each one for a full break down so how much is being used with screen on and screen off.
14-03-2024 05:23 PM
- Mute
- Highlight
Or tried to run a battery diagnostic
14-03-2024 05:25 PM
- Mute
- Highlight
14-03-2024 06:39 PM
- Mute
- Highlight
I'm on 4hr 30 mins screen on time and I have 30% left.
14-03-2024 10:54 PM
- Mute
- Highlight
Like seen in first attached image, it just gave me about 5 and half hours screen time. Which I mainly used youtube and audio apps. And the rest 1hr and something on standby. I do use AOD, I have started using the extra dim for a few days.
I have only recently got 23ultra 256gb, so I don't think I will be going for the reset option 😅.
Also a lot of apps are in deep sleep and the rest I use some social apps, no games recently either.
I do have routine enable for overnight so location, camera, Bluetooth, and data off.
Oh I don't use map or waze often either.
And use of camera drains somewhat battery too . I think that is in all samsung phone if not all phones in general
18-03-2024 07:01 AM
- Mute
- Highlight
