System volume slider does little to no difference in system volume
(Topic created on: 06-08-2022 09:35 AM)
Max Chang
Galaxy S22 Ultra
Currently had a brand new S22 Ultra but the volume slider for System did little to no difference in sound change. System sound like taps on keyboard are extremely soft, even when through galaxy buds. However, the the rest are working as it should.
Products mentioned in this post
5 REPLIES 5
Dragonreb2
Samsung have 4 different sliders that control sound. Press your slider and then hit the three little dots, adjust accordingly ☺
Max Chang
It's all maxed out but the system volume is still too soft
Dragonreb2
Ah, sorry to hear that. You could try Samsung Diagnostics to see if it finds an issue, or take it to a Samsung Shop for a closer look in that case 😔
ThatGuyJacobee
Navigator
Seems like a hardware defect most likely, checked diagnostics to double check and otherwise best to contact samsung via website live chat, or go in-person to an samsung experience store.
Max Chang
I don't think it's a hardware issue, cause audio output such as Spotify or YouTube are working normally via Bluetooth or speaker.
Issue is keyboard presses, screen unlock, those system sounds, are too soft even at max volume especially via Bluetooth.
Could be an issue with the latest update?
