S22 Ultra Screen lag and battery issue
(Topic created on: 21-03-2022 06:30 PM)
pradeepvoolla
Pioneer
I got my phone recently, from the day one having issue with scren which is so lagging and the screen tone changes automatically. The battery backup is not good as well.
I tried resetting it couple of times and it is running on the latest software as well. My S21 Ultra is much faster and guves me good battery backup.
Any suggestions or tips ..
16 REPLIES 16
Krisalex79
Helping Hand
i confirm. same issues here. i have both the s21 ultra and s22 ultra. s22 ultra lasts less than s21 ultra with the same general use. s21 ultra can carry me trough 50 full hours between charges, which os not the case with s22. about 36 hours in, the s22's nattery os depleted, and phone shuts down out of depleted battery.
The FACT that i PRETEND to believe you, DOES NOT mean i actually believe you.
pradeepvoolla
Pioneer
May be they need to release a software update...
Krisalex79
Helping Hand
i will not be surprised if battery and gps issues are related to one another - phone looses signal, starts to actively search until it finds it. durin the search, the battery is drained. this is only a suggestion, not a confirmed statement.
Gauranga
Sorry to hear, Pradeep!
Nevertheless, try this out, and it should help boost battery and performance!
1) Power off your device completely
2) Hold down on the power button and the volume up button and let go of them immediately once you see the Samsung logo disappear
3) Then a recovery menu will appear, which you can navigate using the volume buttons
4) Go down to 'Wipe partition cache' and select it using the power button
5) Then use the same way to navigate to 'Yes' and select with power button
6) Once it's done, it will show the recovery menu again and then navigate to 'Reboot system now' which should be the first option and this will start your phone up again.
DO NOT WORRY! This does not delete any of your data files, images etc. It simply clears out the cache and especially unnecessary cache data. A few people have tried this and seen great improvements in performance and battery life 👍
Krisalex79
Helping Hand
gps issues, screen lag, poor battery magament, samsung has a lot to fix. my ss2 ultra phone suffer all of them. exynos 2200, european series
pradeepvoolla
Pioneer
Thank you for your response,did it couple of times, still no change
pradeepvoolla
Pioneer
Yep, agree, they should have given the Sanpdragon version like rest of the wolrd...
Krisalex79
Helping Hand
yes. whats wrong with us in the European union, so we are given the inferior exynos processor. This is not cool from Samsung.
Krisalex79
Helping Hand
theyn need to release an update and a big one - to fix the not smooth screen issue, to fix the fast battery drain issue, to fix the gps signal lost issue.... i hope they fix all these with a single large update.
