20-10-2024 05:44 PM
21-10-2024 07:08 AM
Check and exclude app you are using from power/battery optimisations. Leave it on unrestricted
21-10-2024 08:26 AM
21-10-2024 08:45 AM
22-10-2024 01:41 PM
22-10-2024 01:58 PM
22-10-2024 02:00 PM
13-03-2025 09:04 PM
23-06-2025 01:44 PM
I had the same problem, affected car and smartwatch. The problem was waze app, I unistalled, restarted the phone(dont know if this is really necessary) and everything started working again. Afterwards I installed again the app, and had no problem.
3 weeks ago
Having the same issue. No new apps, started happening after the latest one UI update. Anyone got more clues? Samsung support does nothing, as usual.
