Battery drain seems an issue
(Topic created on: 10-03-2022 09:39 AM)
meetu
I have been using the phone for 2 days without installing my daily use apps and observed that the battery is draining very quickly. It is not an expectation from a flagship with 5000 mAh battery capacity. I believe other users would be facing the same and request Samsung to look into the issue.
10 REPLIES 10
MrJCharming
Helping Hand
Mine took 3-4 days to settle down
Gadgetman86
Pioneer
I am using my phone on power saving mode most of the time. It's not fair on us consumers.
Samsung need to sort out the battery optimisation ASAP.
mieloncom
Voyager
You should use the phone normally and wait more days the battery will be optimized
Scotcruz
Voyager
Mine is not holding the charged.. does the battery optimise itself?
meetu
Hi,
I optimized the phone settings now e.g. enabled power saving mode, changed the theme to Dark and it seems to be in good shape as earlier. I'll observe it further but Samsung should do some SW changes to optimize the battery for the flagships.
ruuvvi
Pathfinder
What do you mean by draining very quickly? How much during one hour or 12 hours?
I usually charge my phone to 100% in the evening and next evening I'm still having ~50-60% battery left. I'm not using any battery saving modes. I don't  use gaming or watch a lot of videos. Just messaging, twitter, instagram news etc.
Members_eT66blW
Pioneer
Try to turn off wifi, it seems there is a bug preventing the phone from going into deep sleep.
zdun8
Pioneer
What is the source of this information?
Members_eT66blW
Pioneer
Well test it . Turn off WiFi and use AccuBattery or GSam battery monitor to check time in deep sleep. There is no time spent in deep sleep if wifi is on. The idle drain is lower without wifi when connected to 4G. There is some issue with Kernel process that keeps the phone awake.
