Note 10 plus Wi-Fi won't switch to better signal
(Topic created on: 20-04-2020 10:18 AM)
Mohammed_Khalil
I have a router & access-point, and the The mobile once connected to one of them via Wi-Fi, it won't switch to the better signal automatically while I move around the house. I searched and found others facing the same and the solution was to install a third-party application which all requires GPS to be on all the time. My 3 years old Huawei GR5-2017 can do that with no additional application, so i expect your Note 10 plus flagship to do the same. Please help to fix the issue
Current setup:
Router in room A & Access-point in room B
Situation one:
If i connect to router wifi while in room A then move to room B, it wouldn't switch to the access-point wifi and i am still on the one bar weak signal from room A
Situation two:
If i connect to access-point wifi while in room B then move to room A, it wouldn't switch to the router wifi and i am on the one bar weak signal from room B
1 REPLY 1
Phoner
Exactly the same situation, is there a fix for this?
