My replacement s pen won't connect to my note10 lite
(Topic created on: 02-03-2021 10:05 AM)
RobertJ55
Hi,
My replacement s pen won't connect to my note10 lite. Any procedures available to check pen or connection?
7 REPLIES 7
dazjp71
Pioneer
*#0*# gets you to the phones secret test menu, it does have an s-pen test but if it isn't connecting it might not show up there either, just found a YouTube link that might help as well
https://youtu.be/VeNdYgn58Ps
AndrewL
@RobertJ55: Can you try inserting the S Pen into the S Pen holder on your Note 10 Lite > Swipe from the top of the screen to the bottom, then again to enlarge the Quick Panel > Tap on 'S Pen Remote', then tap it again to activate it. Does a flashing S Pen Symbol appear in your Status Bar at the top of the screen to indicate that the connection has been successful?
RobertJ55
Thanks tried this but won't connect
RobertJ55
RobertJ55
Its a replacement pen for note10 doesn't make a difference to just reconnecting resetting the supplied pen I lost?
dazjp71
Pioneer
could be a cheap third party s-pen, my advice would be to return it and get another
RobertJ55
samsung pen via amazon but I have a replacement arriving today, thanks
