04-12-2024 11:56 AM
I bought an A25 5G about nine months ago and within a few weeks I hit battery drain problems. Even when not using the 'phone the battery would drain quickly at around 3 to 4% an hour. Checking the apps which were using the battery did not help as nothing showed up. In fact the total app usage was way way below the amount of battery used. I installed Good Guardians and this did not help nor did blocking notifications. In fact I tried everything I could find to stop the problem and nothing worked. It seems that for no reason something sets the 'phone off draining the battery. For example, the other day it was working fine until I answered a call. During the call battery drain was normal but it did not stop draining after the call stopped. Over the next hour it lost 10% whilst I wasn't even using it and then for some reason it stopped. Initially I found that rebooting it stopped the problem for a short while but then even that did not help. In desperation I did a full factory reset but the only thing that did was waste a lot of my time as the problem persists. I have now been forced into using power saver mode permanently to stop it. I have consulted Samsung and they have been a complete waste of time. Once the 'phone is sold they don't seem to care. I have a nine month old 'phone which is pretty well unusable. Has anyone else had this issue and if so, how did you solve it? It is the complete randomness of the issue which is frustrating me and the fact that nothing seems to stop it. My thanks for any tips you can give me.
04-12-2024 01:13 PM
04-12-2024 02:05 PM
04-12-2024 07:51 PM
Hello @wagnerman and welcome to the Samsung Community Forum 👋
If you perform a forum search you may find existing threads with some further help or guidence within.
A Samsung Service Centre can assess your phone if necessary.
https://www.samsung.com/uk/support/repair/
If i can be of any further help please don't hesitate to ask 😎
Daily Driver > Samsung Galaxy s²⁵ Ultra 512Gb ~ Titanium Black.
I'm here to help. " This is the way. "
05-12-2024 11:03 AM
Thanks for the reply but I regret that it does not tell me anything I have not already tried. As I said in my original post " I have consulted Samsung and they have been a complete waste of time.". All they told me to try was exactly the same things which they suggest on their website. I told them I had done all those things and that was all they had to offer. As far as I am concerned Samsung have sold me a £250.00 'phone and have simply washed their hands of any problems when something goes wrong. I feel as though I have had money stolen from me and I will certainly never buy a Samsung product again. I hope you understand my frustration here.
05-12-2024 11:08 AM
Thanks for the reply. As I said in my original post "Checking the apps which were using the battery did not help as nothing showed up" and "In desperation I did a full factory reset" so you are only telling me what I have said I have already done.
05-12-2024 11:13 AM
Thanks for the reply. I had already tried what you have suggested. The battery stats reset simply does what it says. It resets the accuracy of the battery statistics. It does not have any impact at all on the cause of battery drain.
05-12-2024 11:20 AM
05-12-2024 11:54 AM
Thanks for your reply. I have already tried exactly what you have suggested. I have done a full factory reset and did not use Smart Switch as I read that it can cause problems. I started from scratch and as I only use a very few apps and I re-installed them one at a time to test the impact on battery drain. Location services is off. I can see then'phone mast from my house and I get an excellent signal. In fact I use a 4G router for broadband because my signal is so good. As I mentioned in my original post, the 'phone can be working fine but then an event takes place which starts the battery drain off. The other day the battery was not draining and then I received a 'phone call. This set the battery drain off and over the hour following the call it drained 10% and I wasn't using it. If it were any of the settings on the 'phone, a virus, apps running in the background etc then surely the battery drain would be constant and not random? I have put hours into trying to solve this problem and Samsung have been a waste of time. They simply cut and paste the information about battery drain which is on their website. When the problem first started a reboot would fix it but that does not work now. I may be being overly simplistic but I feel that there is a process going on in the 'phone which does not always cut off and it drains the battery. I would have thought the factory reset should have cured it but alas not. I have to wonder if it is something to do with all the ridiculous and unnecessary bloatware which Samsung put on their 'phones. To say it is driving me crazy is an understatement! Thanks again for your help.
05-12-2024 12:58 PM
