HELP - SSD mounted on powered usb hub keeps disconnecting
(Topic created on: 16-07-2023 02:49 PM)
Nicholas8
My SSD (samsung T5 2tb) works fine on my laptop (dell xps 6300), but not when connected via a usb hub (Anker PowerExpand+ 7-in-1 USB-C PD Media Hub). The SSD keeps disconnecting and instantly reconnecting. It does this every 20 seconds or so.
It works fine when directly connected on the laptop. The hub is powered at 65W via usb PD and powers the laptop at 40W via its fixed usb-c cord, so the hub should be having enough power.
The issue appears when the SSD is connected via either usbC-to-usbC and usbA-to-usbC cables.
Have you dealt with this issue before and how did you resolve it please? I cannot let the SSD on the hub under the circumstances. It is unusable and I risk corrupting the files in it.
Thank you
1 REPLY 1
Pugs1957
SuperStar
This model seems to suffer a lot if disconnections to HDMI and ethernet as well. I would recommend reaching out to Anker for support.
