Go to solution Solved
S95C TV and Q700C soundbar in eARC mode sound drop/cut out
(Topic created on: 06-04-2024 12:24 PM)
TonyMcConnell
Does anybody else have this setup? I’ve got it in QSymphony mode with eARC set to auto and occasionally the soundbar just cuts out completely. Goes haywire in fact, flicking briefly to TV sound and back to no sound via the soundbar.
The only way to stop it it to turn TV audio setting eARC to off. The soundbar software is up-to-date (HW-Q700CWWB-1002.0 21), the TV is up-to-date with version 1402.5 and reckons there are no further ones available. I’m using the HDMI cable that came with the soundbar.
8 REPLIES 8
lance78
Hotshot
Gurky
Helping Hand
Just trying to remember but there maybe a USB update, I had a similar issue with Q800C and QN95C till I did the update.
TonyMcConnell
Interesting. The web update via smartthings fails to find the update. Downloaded and installed via usb, let is hope this improves things. Version is now:
SAT-iMX8M23WWC-1004.0 34
TonyMcConnell
No change, the problem still persists.
TonyMcConnell
FWIW, I contacted support who are at least aware of the issue:
At the moment we don't have the available fix yet, but our engineers are doing their best to rectify this. We'll update you once we have the resolution, Anthony. I really appreciate your patience as we've gone through all this. Should you require further assistance, please do not hesitate to get in touch with us again, and we will be more than willing to help. Just quote your Samsung case, nnnnnnnn for reference.”
TonyMcConnell
There are rumours of an ota version 1410 which is supposed to fix these problems.
hmartires
My OLED TQ65S92 just got a firmware update from Samsung and the problem is fixed now.
Now, when connected with the sound bar, it shows only Q-Syphony and not TV+Q-Syphony as before.
It only happened with streaming services.
Clearly a problem with the TV firmware which Samsung manage to solve. No problem with the soundbar.
