S61B Soundbar Sound Mode problem
(Topic created on: 25-01-2023 09:16 PM)
Ad291
Hi all I've recently purchased a Samsung S61b soundbar
I have it connected via hdmi to a LG oled TV
The problem I'm having is when it's on I used sound mode and say change it to DTS virtual X and it changed the sound mode fine
But after the tv/soundbar is turned off then turned back on the sound mode is no longer turned on the sound is very tinny and faint and I have to manually use sound mode again to change to dts ect
I would have thought upon turning it back on the sound mode would have been saved?
Any advice would be great.Thanks
2 REPLIES 2
Hossimacker
I have the same issue. Need to toggle sound mode via smartthings app 😞 did you find a fix ? I’m connected via HDMI
Ad291
Hi mate, nope it's still the same, tbf it's ridiculous 🙄
