25-01-2025 07:57 PM
Bought a Samsung S95D TV and S800D Soundbar yesterday.
Can’t get Q-symphony to work.
I have connected directly through eArc and have sound in the soundbar, but when I try to activate q-symphony I get a ‘no speaker detected message’.
can anyone help please?
Solved! Go to Solution.
02-03-2025 02:38 PM
I left everything plugged in and just spontaneously resolved after a month?!
29-01-2025 06:27 PM - last edited 29-01-2025 06:28 PM
I have the same problem. For sure this is my last samsung. I'am sending soundbar back to the shop. Tv and sound bar are rubish.
01-02-2025 07:24 PM
Hey there, I had a similar problem today. My Samsung S60D just wouldn’t connect. I tried everything - removing, resetting, disconnecting the TV and soundbar, and even resetting them multiple times. But guess what? It finally connected! I hope this helps you out. Good luck!
10-02-2025 07:33 PM
I've had similar issues with my new Q990D soundbar & QE65S90D TV, with the soundbar dropping and it being very difficult to get working again, however I did find a solution to my set-up. The problem was caused by my Humax PVR being connected to the TV via
HDMI, some sort of CEC conflict. I ended up fitting an HDMI adapter that has pin 13 / CEC disabled to the Humax cable.
No problems since. I used the Lindy 41232 which is widely available.
Might help others if one of the connected devices is the culprit.
02-03-2025 02:38 PM
