Go to solution Solved
Proper Q90R Rear Speakers Placement Help
(Topic created on: 11-09-2020 01:02 PM)
andrzej8445
Hi guys, is there a best angle and spot for rear speakers ? Like space beetwen them, high or angle like rear spekers facing eachothers. My setup is like this :
green - soundbar and rear speakers
blue - TV
yellow - the best place to watch movies
What’s the correct way for my room. Thanks!
AndrewL
@andrzej8445: Ideally you'd want the rear speakers to be spaced evenly behind your head, and pointing towards you, which seems to be the case based on your illustration. For a reference point for the recommend speaker layout, please check page 6 of the user manual.
https://downloadcenter.samsung.com/content/UM/201906/20190628132027295/HW-Q90R_XU_FullManual_00_ENG_...
1 REPLY 1
AndrewL
