Go to solution Solved
HW-Q950T/XU subwoofer and rear speakers keep blowing fuse in plugs.
(Topic created on: 18-11-2021 11:06 AM)
Iana58
Hi,
Anyone had same problem with this bought in April and have to change fuses about twice a month since then?. Tech support have so far only suggested resetting the soundbar and TV. It appears that the fuses blow after device switch off. The sub and rear speakers keep flashing blue light for about five minutes before switch off and showing red.
Iana58
After much soul searching I discovered that the fuses were not blowing as I thought. In fact the speakers were not turning on as expected. An easy fix involved just unplugging and plugging back in again. No idea what the cause is but it only happens occasionally and is easily fixed now,
4 REPLIES 4
Murphmrm
Pathfinder
Quite normal for the blue light to stay on for a few mins. That's annoying but not an issue. Don't know what country you are in or if you bought the system as an import...Read the manual regarding power voltage fir your system
Iana58
In UK and purchased from Currys
redruMKO
same - surrounds have blown fuses about 3x each now in 9 months
did you return ?
Iana58
