HW-Q90R soundbar does not pass through Dolby Vision HDR signal
(Topic created on: 20-12-2019 02:39 PM)
abc123xyz
Update:  I can get Dolby Vision passthrough now! You simply have to turn of the HDR10+ functionality on your Panasonic OLED: TV Settings>Setup>HDMI HDR setting>HDR dynamic setting>HDR10+ Functionality = off
I tried to connect my Apple TV 4K (ATV) to my HW-Q90R soundbar to pass through a Dolby Vision HDR (DV) signal to my Panasonic GZ1000 TV. I have also tried this with my Xbox One X (XB1). I was using the Netflix and ATV+ apps. Both devices fail to pass the DV signal through my setup and all I get is HDR10. However, I have read that others have had success passing a DV signal through. I have checked all my settings on all the devices in the chain and they are correct. I am using ultra high speed 8K 48Gbps HDMI cables.  I have also tried connecting the sources directly to the TV and then DV does work.  The problem is then I get really bad lip-sync issues when passing the sound through the TV to soundbar, which eliminates this setup as a solution. I am posting here to hopefully get some feedback from other people who have either successfully passed an ATV or XB1 DV signal through their HW-Q90R and also those that have failed to do so. I am interested to see what TVs, video sources and apps you are using, especially  when using ATV or XB1. I find it very frustrating  and annoying that two common sources can't be used with their optimal video signal considering that the HW-Q90R is Samsung's flag ship soundbar.
23 REPLIES 23
Facakente
I know it does not support , what I meant was any setting in this case hdr10 that needs to be disabled to pass the DV through .
But as I said if in the c9 works , it should also work in cx
Largo1
wrong post
Anonymous User
Not applicable
This only got me part of the way for my Apple TV 4K and Q90R soundbar and Panasonic OLED 55GZ1000 TV,
So I needed to do this:
Also
TV Settings>Setup>HDMI Auto setting> mine was set as "Mode 2" by default". I had to change to "Mode 1" for Dolby vision passthrough to work.
Once I switched to "Mode 1" the Apple TV 4K came up with a box asking me if I wanted to use Dolby Vision, I clicked yes and it worked, however if you don't get a pop up box then I think you can achieve the same thing by going into the Apple TV 4K settings, and activating Dolby Vision under the video settings.
I tested it out with the Lasso TV series on Apple TV and I now have Dolby Vision passthrough working as well as Dolby Atmos working with no audio delay lip sync issues, Finally!
Oh and I also had to update the Q90R firmware, I believe I am now on version 1012
Anonymous User
Not applicable
With help from those on the original poster I got Dolby Vision passthrough working with Q90R sound bar:
So my gear is Apple TV 4K and Q90R soundbar and Panasonic OLED 55GZ1000 TV, So for me I needed to do this: On my Panasonic OLEDTV = TV Settings>Setup>HDMI HDR setting>HDR dynamic setting>HDR10+ Functionality = off Also On my Panasonic OLEDTV TV Settings>Setup>HDMI Auto setting> mine was set as "Mode 2" by default". I had to change to "Mode 1" for Dolby vision passthrough to work. Once I switched to "Mode 1" the Apple TV 4K came up with a box asking me if I wanted to use Dolby Vision, I clicked yes and it worked, however if you don't get a pop up box then I think you can achieve the same thing by going into the Apple TV 4K settings, and activating Dolby Vision under the video settings. I tested it out with the Lasso TV series on Apple TV and I now have Dolby Vision passthrough working as well as Dolby Atmos working with no audio delay lip sync issues, Finally! Oh and I also had to update the Q90R soundbar firmware, I am now on version 1012.6
This probably only helps those with a Panasonic OLED TV.
