Help identifying cable from Samsung subwoofer
(Topic created on: 10-11-2023 03:51 PM)
ftc_homelessapien
Hi all
I am wondering if I can use my existing Samsung PS-EW1-1 subwoofer with another sound system. I originally bought this as part of the Samsung HW-F350 soundbar. The soundbar itself no longer works and has been discarded but I have kept the subwoofer.
Specifically, I would like to know the name/type of cable used for the PS-EW1-1 unit. I have never seen this sort of cable before, and understanding what it's called/its specifications would help me narrow down its compatibility with other speakers/amplifiers, etc.
I have attached photos of the cable. The wire is coiled around some sort of housing unit halfway as the original installation instructions suggested. Perhaps this helps narrow the cable type down. I
would be really grateful if someone could help me identify this!
Thanks in advance
1 REPLY 1
Ginga_p
Hotshot
Its called a ferrite bead it cuts down on high frequency interference. With bog standard wire the plug makes it a problem. You cant use it with a traditional av receiver as you need a active speaker.
G G
