06-10-2019 06:34 AM - last edited 06-10-2019 06:36 AM
Hi everyone.
I own a Samsung UA32N4300AKXXT and I'm using it together with a third party soundbar. The soundbar is making very weird crackling sound when using Tizen apps, BUT only on some apps (f. ex. Amazon Prime Video). Other apps like youtube are just fine. TV and soundbar are hooked up with a toslink cable.
I tried to update the firmware but it was already up to date. Any idea how to solve this problem?
Solved! Go to Solution.
10-10-2019
12:01 PM
- last edited
10-10-2019
01:37 PM
by
AntS
Hi SaudA,
Thanks for your answer.
I was able to resolve the issue by following the advice of user "root_kitten" in this thread:
https://us.community.samsung.com/t5/4k-8k-and-Other-TVs/Optical-audio-output-not-working/m-p/674771/...
Edit: root_kitten's advice:
"I had a similar issue, solved by doing what others are saying (set digital audio output to PCM) and then setting the output as TV speakers instead of the digital output itself. I then unplugged the cable and plugged it back in. Suddenly I could hear both from the TV and the speakers. When I switched it to just optical out it only came through the speakers.
I think it may have to do with the fact that I plugged the Toslink cable into the TV while it was still configured for Dolby and bitstream. Replugging it in with PCM set as output caused it to work exactly how I wanted it to!"
08-10-2019 10:52 AM
10-10-2019
12:01 PM
- last edited
10-10-2019
01:37 PM
by
AntS
Hi SaudA,
10-10-2019 01:23 PM
10-10-2019 01:39 PM
@AaronBKK , Did a quick edit of your post just in case that link ever gets broken.
24-05-2022 05:13 PM
You fixed my life i opened an account to say thanks
