Go to solution Solved
27” monitor sound issues
(Topic created on: 12-08-2021 06:45 PM)
Anonymous User
Not applicable
Hello Please can someone tell me how to connect monitor to an external speaker. On my speaker I have charge port and 3.5mm port, it also as Bluetooth. My monitor as got headphone port, hdmi and vga. It does not have Bluetooth. I do not necessarily want to just headphones in monitor. Thanks in advance.
antikythera
Black Belt
Headphone port on the monitor to 3.5mm input, you'll need to buy a cable for that but they aren't expensive. Be aware that if you connect a computer over VGA it doesn't carry sound to the monitor, only HDMI will. So with that in mind you may want to connect the 3.5mm to 3.5mm stereo speaker cable to the green output on the back of your PC to your speaker input.
2 REPLIES 2
antikythera
Black Belt
Anonymous User
Not applicable
Thanks for reply all sorted.
