Go to solution Solved
samsung wireless charger portable battery help.
(Topic created on: 15-02-2021 04:31 AM)
Welshy-a53-5G
Pioneer
I'm looking to buy a wall plug for my samsung wireless charger portable battery but I'm struggling to find one, I have a 25w USB type-c one spare that came with my s20, since the battery pack is charged using a type-a wall plug would it be possible for me to buy a type-a to type-c adapter and use my 25w type-c plug? I'm sure it works I just want to make sure a 25w adapter wouldn't be too much.
CrazyTom2k2
Helping Hand
Hey there Welshy2001!
You don't need to worry about buying a charger that's too powerful - your portable battery is smart enough to "talk" to the charger to negotiate power 🙂.
If you're looking for a charger, you can use the one that came with your S20 - there should also be a Type-C to Type-C cable in your S20's box.
Hope this helps
Tom 🙂
1 REPLY 1
CrazyTom2k2
Helping Hand
Hope this helps
Tom 🙂
