01-08-2022 04:09 AM in
My EB-U3300 portable wireless charger stopped working recently. No LED light comes up when connected to a charger and the little LED flashes red, green, and amber when the button is pressed several times while it's connected to a charger. Is my beloved wireless charger dead??? Any fixes?
07-10-2022 12:45 PM in
Same here. It stopped working for no reason. Now it will not charge anymore. When connected to the charger and the buttonnis pressed, I get the red green amber flashing, that's all...
12-10-2022 05:11 AM in
Not sure if this is helpful but you might try a reset by holding down the power button for about 7 seconds until the white lights go off and on again. I read about that while researching a different problem with my eb-u3300.
