S9 LED flipcase not working
(Topic created on: 30-08-2020 03:40 PM)
sevrahjames
I have the LED wallet case on an S9 that will not longer display anything like the time, audio controls, or notifications. It started to do this just last week after doing a system update. I have had this happen before and I can usually fix it by taking out the phone, restarting, and putting it back in, but that doesn't work. I have aslo cleared the cache and messed with the settings to no avail. My phone does read that there is a cover in accessories. It's rather annoying and I really like features of the case. Is there any other fix, or at least any one else reporting this issue? My husband's Note 9 is also having this problem. Thank you.
1 REPLY 1
RudeDawg3
You need the new case unfortunately, it's a known problem on the android update. The new case has a revision 1.1 update sticker next to the bar code in the rear. I just charged mine wirelessly and the case started working. Try using your wireless charger if you have one.
