Sound Balance Issues When Switching Between One And Both Buds on the Buds 3 Pro
(Topic created on: 26-01-2025 11:33 AM)
Jeebs
So I recently got some Buds 3 Pro, and I'm experiencing a weird issue, was wondering if anyone else is noticing the same thing.
If I put both earbuds in, listen to music, then take one bud out (either one) and return it to the case, listen for a bit longer, and then put the removed bud back in my ear and continue listening, the sound balance changes each time I switch between one and both earbuds. It's like the sound has shifted quite a bit to the one that remained in my ear. Like the sound is coming from the left or right of me, not in the centre like it should.
If I perform an ear fit test again after this has occurred, the balance moves back to the middle and the sound is much fuller. It's quite a noticeable difference. The reason I experience this issue is I regularly have to switch between one and both buds when using earbud style earphones.
Has anyone else experienced the same thing?
1 REPLY 1
Niremo
I get the exact same issue. Also happens if you pause the music, rub the ANC mic for one earphone for a few seconds and then play. Ive submitted to samsung the log files for my buds and reported the issue so hopefully they figure out what is going on.
