Dear All,
When I first got my Gear S3 Frontier, I was very happy with the watch. A charge of the battery used to last me at least three days, and that was fine by me. Then suddenly, the battery started being completely drained within about 10 hours.
I thought that probably I have a power-hungry app installed, did a reset, install only trusted apps I have been using for a long time, and everything seemed fine again, battery lasts three days. I thought at the time that the issue had been resolved.
However, a few days later, the same thing happens again... and again... and again... ever more frequently... it seems to happen particularly after episodes of the watch having lost BlueTooth Connection to the phone, e.g. because of having been in airplane mode -- I travel a lot. On a side note, I also have the BlueTooth reconnection issue that is being dealt with in a different thread, and may or may not be related.
I have had the S3 Frontier now for about 7 months, and it has now become virtually impossible to use it for a full day. Even resets no longer resolve the issue. I have done a reset and not installed *any* apps, and yet the battery lasted only 10 hours(ish), so it's not just one dodgy app...
Anyone any ideas...?
23-07-2018 09:02 AM in
WearablesAnother issue that has come to light relates to charging.
I've noticed a couple of times that despite being on charge overnight when I wake up in the morning, the watch is still not fully charged.
The only common factor has been that the phone has died before the end of the day despite me putting it into low power mode. So when the watch is put on the charger, although it is dead, it remains in low power mode.
I'm going to try charging for a few minutes if this happens again and then switch it to normal power before leaving it overnight to charge.
17-10-2018 05:23 PM in
Wearables18-10-2018 01:51 PM in
WearablesYesterday and today, mine has drained after factory reset from 100% to 0% in approximately 6hrs.
18-10-2018 04:55 PM in
WearablesMy Gear S3 Frontier was fully charged when I woke up for work this morning, and when I left for work at 6:30am, I noticed it was at 53% and thought maybe i read it wrong this morning. At 10:00 it was at low battery and right after that it shut down. Need this fixed!!!!!
19-10-2018 05:20 AM in
Wearables19-10-2018 09:59 AM in
WearablesHi,
Daughter purchased my S3 Frontier for Fathers Day 2018. It has benn operating just finne runiing for 2-3 days between charges until recently. With a full charge the watch is down to under 15% within 8hrs use.
I have reimaged and reset watch but still have the same issue.
Please advise on fix for this issue.
I am located in Brisbane, Queensland, Australia.
Thanks
19-10-2018 11:12 AM in
WearablesMy started to suffer the same about 3 days ago, I did factory reset twice to see if that would help, but it did not. I tried with 2 different charges just in case, didn't help. There's gotta be something software ralated
19-10-2018 12:19 PM in
Wearables22-10-2018 03:50 PM in
WearablesI had the same problem with my S3, my battery suddenly begun to drain fastly with no increase but normal usage. This is what I did and it works for me.
First I made a backup of my stuff, and then reset the watch. When it came up again, I realize that there were some app's that needed to be updated, even if I search for them before and said to me that no updates were necessary. Then I downloaded my backup from the cloud and from there I have my watch running at a normal battery drain again.
Hope it helps.
07-11-2018 09:15 PM in
WearablesHappened to me some weeks ago.
Handed it in for waranty repair.
They changed the motherboard. Uncertain if they changed the battery.
Before it was down 10-11% per hour. Now after repair it is down 9% in 5 hours. Looking good.
