Dear All,
When I first got my Gear S3 Frontier, I was very happy with the watch. A charge of the battery used to last me at least three days, and that was fine by me. Then suddenly, the battery started being completely drained within about 10 hours.
I thought that probably I have a power-hungry app installed, did a reset, install only trusted apps I have been using for a long time, and everything seemed fine again, battery lasts three days. I thought at the time that the issue had been resolved.
However, a few days later, the same thing happens again... and again... and again... ever more frequently... it seems to happen particularly after episodes of the watch having lost BlueTooth Connection to the phone, e.g. because of having been in airplane mode -- I travel a lot. On a side note, I also have the BlueTooth reconnection issue that is being dealt with in a different thread, and may or may not be related.
I have had the S3 Frontier now for about 7 months, and it has now become virtually impossible to use it for a full day. Even resets no longer resolve the issue. I have done a reset and not installed *any* apps, and yet the battery lasted only 10 hours(ish), so it's not just one dodgy app...
Anyone any ideas...?
19-08-2017 06:32 PM in
WearablesTo me it sounds like it's time to get a diagnostic run on it via a Samsung Experience Store or Samsung Service Location @RedWolf
Current Phone ~
Samsung Note 20 Ultra 5G SM-N9860_256Gb SnapDragon 865+
Samsung One Ui 3.1/ Android 11.
29-08-2017 08:04 PM in
Wearables08-09-2017 10:19 AM - last edited 08-09-2017 10:20 AM ) in
WearablesHi,
I had the same problem for months after the update but I can report that my problem is solved.
Here in the Netherlands, Samsung has a Facebook messenger option. I submitted my issue and they promptly answered. After asking the standard questions (reset, factory reset, pairing with other phone, etc) they gave me the option to have it picked up for service. The very next day a courier swung by and picked it up in a sealed container. 3 days later, I received notice that it had been repaired and be delivered by the same courier, free of charge.
Upon receiving my Gear, I really wasn't thinking it would be repaired by was proven very wrong. The motherboard and battery were replaced and also given a software update.
The watch is working perfectly ever since. Long battery life (3 days easy!). Can now sleep with it on to monitor my sleep and also during my workouts.
It came off the charger this morning at 8:30am and still has 99% battery left.
My guess is that there could be a faulty component on the board that only presented itself through the software update everyone is talking about. That would also explain my bluetooth connection issue I was having with my phone and Harmon Kardon bluetooth speaker. It was having dropouts while also connected with the Gear. That problem is also solved with this repair.
Hope this all helps!!!
28-11-2017 07:38 PM in
Wearables03-03-2018 04:28 AM in
WearablesI have a same problem. But one thing i have noticed battery drain problem isn't in gear s3 because when we use gear s3 without any connectivity it works fine but we connect than battery drains very fast.
03-07-2018 11:46 PM in
WearablesMy Gear S3 is three days old and has been draining the battery from day 1 so not sure your solution is correct.
18-07-2018 04:40 PM in
Wearables18-07-2018 05:00 PM in
WearablesUpdate:
I took my watch back to basics and shut everything down.
The problem was still occuring. My next move was to shut down the gear app on my iphone and the health app.
This has changed everything. Previously it must have been constantly looking to connect and sync and as a result the battery was draining in a matter of hours. When I open these apps now, they immediately sync so they are always up to date but there is no dramatic drain on the battery.
If i use the 'always on' option then I am getting just over a day before I need to recharge. If I turn the 'always on' option off, then I am getting 2-3 days before needing to recharge.
Still not brilliant but much better than before.
19-07-2018 08:20 PM in
WearablesSo I spoke too soon yesterday saying the problem appeared to be fixed.
Charged the phone overnight, it started at about 37% when I put it on charge. When I woke up this morning it was only on 78% so despite charging all night it hadn’t charged properly.
I took it it off the charger and put it back on charge for about 90 minutes. By this time it had reached 99%. This was at 07.00 in the morning.
At about 13.15 the phone came up saying low battery and to put into low power mode which I did. By 14.00 the phone was totally dead.
This is a farcical situation. What a piece of c**p. Not sure what I’m going to do yet but I need a solution urgently.
