M/L strap too small
(Topic created on: 21-03-2024 10:19 PM)
SammyPee
Hello,
I have purchased a Watch6 Classic, which has come with a M/L strap. Unfortunately this just fits and even then is tight.
Is there any straps compatible or recommended which would be suitable.
I would like to keep the black leather look strap and I like the fact it is faux leather.
I could be tempted by the Samsung velcro fabric strap if it would offer a better fit, but am unsure if that would be the case.
Any help or opinions would be appreciated.
Thank you
8 REPLIES 8
Bigtasty65
Big Cheese
Have you thought of piercing just one more hole in the strap might help?
georgieboy
Navigator
Are you sure it's M/l I just got a watch as well and I have big wrists
georgieboy
Navigator
And it fits well 😁
SammyPee
I did think that but I wasn't sure if that would weaken the strap.
SammyPee
Yeah mate, says M/L on the strap. Initially I thought it was a Small one.
Fitbit M/L fits me fine.
Bigtasty65
Big Cheese
I know what you mean but they are made of silicon. So should be fairly durable.
What colour Watch did you get? I got the grey/chrome Watch 6 Classic. I absolutely love it. Samsung did a superb job with it. Coming from the Watch 4 Classic, you wouldn't of thought 1mm more display size would make a difference. I think it certainly does to the usability.
HootleTootle
Voyager
Look for the Sasquatch sized straps on Stuffforbigfoot.com
Also make sure you're not putting your watch on your leg. It's supposed to go on your arm.
Bigtasty65
Big Cheese
