Go to solution Solved
IP rating and ATM rating after screen replacement?
(Topic created on: 06-05-2025 09:02 AM)
NEVARLeVrai
Hello,
Just got repaired my watch by my reseller Boulanger that send the watch normally to an official Samsung center, and they changed my watch screen, so they open it, does the IP rating and ATM will remain ?
Thanks
Glenntech
Samsung Members Star ★★
If its done using an official Samsung repair agent
And original parts used
Then the work will be guaranteed and should retain the original specifications
But consult the repair agent to get an official reply about it
3 REPLIES 3
Glenntech
NEVARLeVrai
Will ask my reseller to be sure
ricky777726
Pathfinder
I had a screen replacement on my s23 ultra it was done via an official Samsung repair partner, and it's still waterproof they replace the waterproof seals
