How to improve battery life on Waych4 Classic 42mm
(Topic created on: 30-10-2022 12:48 AM)
JoeBiden1939
The battery life absolutely sucks it barely even lasts a day even with power saving enabled. Is there a way to improve the battery life??
3 REPLIES 3
-Robot-
Samsung Members Star ★
I have juae traded my watch in, it used to last over 24 hours. It was annoying that I pretty much had to charge it once a day and I had everything on except some of the continuous monitoring
But it would last more than a day, I would get day and half
Goldegg
There's a few things...firstly there might be damage internally with battery.
Adjust screen brightness to blue filter if not available try to on daylight saving.
Disable background apps and close tabs.
Lastly of a night put the phone on bedtime mode, you can still use the phone it sets the whole device to greyscale as the richness from colour hues and saturation in photos and running apps absolutely chews through phone batteries.
Hopefully this helps
If not so another last tip is look the question on app call Quoria (basically a new very of Ask Jeeves) or look up on YouTube
Good luck.
ladyann76
hello all.im a senior.my phone charges faster when iits off.for some reason it will not turn off.i know how.it just says charge yr phone.charghing when on takes 2 hours.do you have any ideas plz
