HELP... one UI 8 firmware broke my GW Ultra
(Topic created on: 13-08-2025 11:51 AM)
happytoon
Pioneer
Please help....
Since upgrading to One UI 8 eu stable version on my GW Ultra. I can no longer measure blood oxygen (manually or during sleep) and the Antioxidant measurement worked only once and never again after that....
When i measure the blood oxygen manually the watch display a blue and red bubble animation... goes up to 99% and then get stuck (never complete to 100%
Ar night the red LED are on but no blood ox reported in the sleep data nor the blood oxygen data.
Antioxidant measurement stay on the gray ' measuring' circle (the watch sensor LED are on) the circle never progress (stay gray) and then time out.
I have chated with Samsung and tried:
- clear cache phone wearable app, cleared storage....
- reinstalled phone wearable app
- clear the watch cache
- reset the watch to factory (about 10 times) and re set the watch.
- send the watch for repair to Samsung (came back today with no fault found... all hardware test passed)
What can I do next ???
PLEASE HELP...
Thanks
6 REPLIES 6
Bindex
Samsung Members Star ★
Hi, I will try and find a solution for you; thank you for posting all the steps you have taken down below.
Navigate to the wearables app, then Watch settings > health > sleep, and confirm that all toggles are enabled; if they are, disable and re-enable them to check if that resolves the sleep problem.
Let me know, if this fixes your issue with tracking your Co2 levels during sleep.
Tech Enthusiast | Need tech help? Just drop me a message!
happytoon
Pioneer
Yes they are on this is the first thing in checked when I noticed i no longer had the pulse ox during sleep. Thanks anyway.
Bindex
Ah I see, this is strange then I have the OneUI 8 update and mine tracks fine, I will check and see if I can find anything else online and see how they fixed the issue.
Members_ZaqGLWK
Good afternoon,
I have the same issue than Happytoon. I did everything he did and it still does not work, did you find any solution to this problem? I found many other people with the same issue online, this should be elevated to a higher level as normal fixes don´t help.
Respectfully
happytoon
Pioneer
I am battling this with support for a month now. Yesterday we apparently escalated the issue with higher support at Samsung. I am waiting to hear from them next week.
Kaboom86
Any updates from samsung?
