Gear smartphone app - annoying charging notification for gear S3
(Topic created on: 21-02-2018 10:36 AM)
col1
I don't want to wear the gear all around the clock and in the bedroom.
In the evening i put the charged Gear on the table.
After ~1 hour the Gear-App on my smartphone makes a notification (with signal and vibration!!) to make me put the (full charged) gear into the charging dock (Very 'nice', if i just fell asleep 😕 ).
I can't find a switch on my phone or app to deactivate these messages or make them silent.
This is really very annoying. It's MY decision when to charge it - or not.
My workaround is to power off the gear if i don't use it. But this is annoying, too.
Any other suggestions? :smiling-face:
Gear App 2.2.20.17113061 / Gear S Plugin 2.2.03.18011961
Samsung Galaxy S7 SM-G930F  / Android 7.0
Gear S3 Classic (5DA4) SM-R770 / Tizen  3.0.0.1 / Softwareversion R770XXU2CQL1
1 REPLY 1
Baza
Iv been getting charge notifications every hour since the latest software updated I contacted samsung and there reply was usless Id already reset and updated before I contacted them and thats all thay could advise. I never got these notifications before the update ... good luck sorting it out hope you get further than i did
