Go to solution Solved
Gear s3 frontier charging issues
(Topic created on: 02-02-2018 07:02 PM)
Nj3
Paid £359 after 5 months suddenly stopped charging to 100 % eventually would only charge to 97%. Sent off to Samsung 8 days later sent back now will not charge past 92% and says will take 1hr 45 mins to charge to full having been on charge for 6 hrs. They will not give me refund or replacement. They clearly did NOT test it at all at the repair centre it has come back WORSE than before. All they will do is take it back so another inconpetent engineer can not do his job properly. SAMSUNG CUSTOMER SERVICE SUCKS....The S3 was not cheap and they don' care. Be warned go for a different make.
Go to solution
12 REPLIES 12
ChrisBEAR
Are you using the original Samsung power supply and charging cable?
AmardeepSinghG
YES
I am using the 100% original & genunine Samsung power supply and charging cable.
Rozy
Your gear is overheated...
Use some small fan or keep in the fridge when changing...
This will help definitely...
