16-12-2021 10:37 AM in
WearablesHello,
For some reason my Watch 4 doesn't ring when I receive a call. I've checked the settings (Sound is on, nothing is on muted, do not disturb is off) and all seems OK. Does anyone have any ideas?
Thanks!
16-12-2021 10:59 AM - last edited 16-12-2021 10:59 AM ) in
Wearables16-12-2021 11:11 AM in
WearablesHi!
Thanks for your quick reply! Very much appreciated! I checked all the settings, all seems to be OK. Not ringing though... I'll reset the watch. Hope that'll help.
Cheers!
27-04-2022 04:23 PM in
WearablesI have same issue
Re set it numerous times after I paired it my new phone . Sound is on . It just vibrates and I can't answer calls like before.. .. annoying to say the least
20-05-2022 02:59 PM in
WearablesFor sure this is so annoying. It happens often. 2 things that seemed to help. 1. Restart the watch. 2. I find quite often that the permissions for watch have been turned off (why?). When I allow watch to make calls etc.it seems to help.
