01-01-2023 08:22 AM
My Galaxy Buds Pro right earbuds is draining battery much faster than the left one. in 5 min. my right earbud is down to 94% and the left is about 99-97% is there any solution to this?
01-01-2023 11:25 AM
01-01-2023 01:25 PM
@Painless Admiral: If you primarily use the right Bud to issue commands via the touchpad, then this may also explain why the battery is draining a little faster on that side. As a troubleshooting step, try using the touchpad on the left Bud for short and long press actions, and check to see if you notice a similar level of drainage.
02-01-2023 08:17 AM - last edited 03-01-2023 01:24 PM
@ytnzzn I see, thanks
02-01-2023 08:18 AM
ok i'll try. thanks
03-01-2023 01:23 PM - last edited 03-01-2023 01:24 PM
@AndrewL still the same. when i used the left bud for short and long press actions the battery does not drain as much as the right bud. around 1 hour and the right bud are at 66% and the left bud is at 82% even tho i was using the left bud for press actions.
16-08-2024 10:59 PM
30-08-2024 03:58 PM
I have the same problem with buds 3 pro.
Afte 2 hours of use:
Left one 43%, right one 15%.
27-02-2025 12:04 AM
I have the same problem, have you found any solution to this?
