Galaxy buds case not showing light indicator
(Topic created on: 27-12-2019 06:55 PM)
LoganLawton
Im having this problem with my galaxy buds where when I open/close the case the light indicators don't come up letting me know the battery of the buds or the case. I know that I can find the battery of the buds in the galaxy wearables app but I cant find the battery of the case which makes this problem really annoying. I use a wireless charger and the lights come on while they are charging but don't when they aren't charging. I have just tried using a cable to see if this fixes anything but no, all that happens is the lights work when I open and close the case about 2 times and then it just stops and doesn't happen again. Is anyone else having this problem or just me, or are mine faulty and should be taken back.
Thanks for reading!
1 REPLY 1
CarloL
Hotshot
Hey @LoganLawton! Are you still having issues with this? Have you tried using the original cable that came with the Galaxy Buds to charge the case?
