Galaxy Buds 3 and Buds 3 Pro allergic issues?
(Topic created on: 10-08-2024 03:37 AM)
tweetatoo
Pathfinder
Hello everyone!
I bought previously multiple Buds models including the Buds Pro, Buds 2 and Buds 2 Pro. Unfortunately I had to return them all at the time due to the severe ear irritating and everything reaction they caused which needed days to weeks to heal.
So my question is to all of you who had developed similar allergic issues before upon Buds use and tried now the new Buds 3 and/or Buds 3 Pro to share with us their experiences so far in this regard.
Any allergic issues or ear irritations so far from the use of the Buds 3 series?
Thank you very much!
19 REPLIES 19
Wilky76
I also suffered from major ear irritation which started with the Buds Pro, I've got my Buds3 Pro on order but I've been reading conflicting reports, some are saying they cause no irritation like the past buds did, while others are saying still getting the same problems as the past buds. hmmmm
Mine are due on the 16th & will be putting my ear health at risk just to see if they cause me any reaction, & if they do I'll shall report my result's on here to warn other that also suffer to stay away from them & not risk trying them, it's going to be a terrible couple of weeks if they do cause any reaction. 😞
MrFinland
Pathfinder
I used to get that from silicon tips, but the problem was sorted when I switched those to foam ones.
tweetatoo
Pathfinder
Many reports out there mention that this workaround with the foam tips does not always work.
Fiona26
Samsung Members Star ★
Mine have changed to preparing dispatch, arriving Monday. Also had issues myself. Will let you know how it goes.
Funmi83
Pioneer
I had to return the Buds 3 because of irritation in my ears, just like the buds 2 and FE.
siasassassin
I got the buds 3 on the 11 aug yesterday use the for 5 hr then wake up with a ear infection but I have the buds and the buds 2 fe and had nothing wrong with them No irritable, no soreness And no allergic reaction
EVANG1969
Yep, Buds 3 Pro give exactly the same issues allergy wise. Such a shame for such a good product. Samsung Helpdesk (NL) however, is trained from the issues in the past and does not want to take back/take responsibility. So seems we are left in the cold, as Samsung fans.
Members_C8BpaKS
Same problem for me.  Ear infection when i use my Buds3 pro. Will try replacement tips when they are availble.
Ryler007
The problem is not the tips as initially I bought the Buds 3 which don’t have silicon tips or any tips for that matter. The problem lies with the housing of the actual ear buds themselves! Samsung releases the same material time and time again!
