Buds Live pip pip pip sound
(Topic created on: 07-03-2021 06:07 PM)
Londinense
I have on occasion had a rapid "pip pip pip" sound come from one of the buds, whether it's paying music or not. What does it mean?
4 REPLIES 4
snackerjacker
sounds like the battery is too low and the buds need charging
Londinense
I didn't think it was that. It has just happened again only minutes after taking the buds out of the case. Maybe the case itself needs re-charging. I'll try doing that, but it's strange that there is nothing in the manual to explain what the sound means!
By the way, I use an iPhone SE so the app doesn't work on that and can't check that way.
Aklima
Big Cheese
Hi,
You can see if ur galaxy wearable needs an update and see the difference or you can block the touch sound.
Londinense
App doesn't work on iPhone SE (too old!). What I might do is pair it with a friend's newer phone and check for updates etc.
