Buds 3 pro muddy sound
(Topic created on: 24-08-2024 10:11 PM)
ankuxab
Everybody keeps saying that Buds 3 Pro are an improvement when it comes to sound quality compared to Buds 2 Pro, but I'm no hearing it. In fact I find the sound muddy, lacking dynamics, very flat, disappointing. I played with different settings, with equaliser, changed he tips- all to no avail. I'm playing lossless files (flac). Why is the sound so bad? What am I missing? Help, please, as I'm ready to throw these new Buds into a very deep drawer or send them back to Samsung...
#Buds3Pro
6 REPLIES 6
Obsydian
Samsung Members Star ★
Interesting all the reviews I have seen suggest the sound is a bright, don't know if you have a diagnostic modes @JAMES4578 or @TechZilla any help as you both have a pair.
2 Decades Samsung Ownership, If my response helps leave a Like and Accept as a Solution
DAILY: ZFold6, Watch Ultra, Fit3, CL Ace 2, BT-W6, 20,000 Power bank, Smart Tags
FAMILY: ZFlip5, ZFlip6, Watch6 Classic, Tab S8 Ultra, Tab S7 Plus, Buds Pro2, Buds3 Pro
OFFICE: Book2 Pro i7, M70A 32”, Logitech K700, MX Ego, M720 Triathlon, Pop, Jabra Evolve2
AV/GAMING: QN95A 50” TV, Q900A, SW900s, 8 Series TV, LG OLED, M70A 43”, Dell Inspiron G5
APPLIANCES: Jet 75 Vacuum, MC32 Oven, American Fridge, 8 Series TV, LG OLED
SPARES: ZFlip4, ZFlip3, Buds1 Pro, Buds2 Pro, Book2 Pro i5, Level Speaker
MAINTAIN: iPhone 14, iPad Air4, iPad Mini4, iPad Pro1 12.9, Watch6
JAMES4578
Samsung Members Star ★★
Hi @ankuxab , It is not my experience, you can check the Diagnostics via Samsung Members.  If ok there do you have the latest updates and is there no difference between different modes,do you have the best sound settings on the phone?  Dolby Atmos should switch off when 360  Audio is enabled.  Assume the app is indicating that you have a good fit, which device are you using? The maximum  Bluetooth range is 10 metres.    Whilst debris can effect  Sound if you have not had the Buds that long unlikely to be the issue.   You could Factory Reset, otherwise  if still problem after all Troubleshooting unless you have a defective pair somewhat surprising.
TechZilla
Im not sure what is going on with yours, mine certainly sound dynamic, loud, and excellent quality. Have you switched on UHQ sound quality in the app? Have you also checked the settings in the phones sound quality and effects settings?
TechZilla - Samsung Members Star
ankuxab
Done all that, software up to date, fit checked, I also checked (and played with) the settings both on the buds and on the phone (24 ultra). I managed to get it sounds a little bit better by turning off 360 sound on pods and turning on dolby atmos on phone (can't have both on). But that's a minor improvement. My old buds 2 pro still sound better. I am starting to think they might indeed be defective. Well, off to talk to Samsung, I guess. Thank you for your suggestions.
simonSK1990
well the same, Im coming from Jabra and the sound quality in Jarba is way better than the galaxy buds pro 3... 2 days Im playing with EQ,  UHD setting, Dolby, everything, the music just sounds dull, no bass depth, no nothing. Overall I had a very bad experience with my Galaxy buds 3 pro, left earbud lost sound 1 week after usage and it took more than 2 weeks for the retailer to just tell me that they will replace them to new ones (you don't say), once getting the new ones looks like the sound quality is not as good as I expected
VladimirDel
Hey bro. Any update on this? I have the same issue. Mine are 1.2025. batch.
