Battery drain watch7 40m and also S24
(Topic created on: 09-01-2025 12:50 AM)
Filip287
Hello, I would like to said something....
I just bought S24 phone and watch7 40mm like 2weeks ago. Both devices are draining battery so fast that I dont know if this is flagship mobile/watch.. like HOW CAN IPHONE HAD BETTER BATTERY DRAIN WHEN THEY HAVE ABOUT 3000mah ???? My watch7 40mm for example are 100% at 10am and at 9pm they are like 10%(bluetooth, wifi and alwaysondisplay is OFF) and Im not doing on the watch nothing.. BUT I WOULD LIKE TO HAVE THIS FUCTIONS TURNED ON.
My phone (S24) is discharging like 12% in hour and im just 2-3hours on mobile per day... for example at 9am have 100% and 7-8pm have 15-20% ??? My older phone with bigger screen realme GT master 4300mah have better battery drain after 3years of use, this phone will go atleast from 8am to 9pm and I was on the phone 6-7hours per day and 30% left there. If I want to be on the S24 6-7hours per day I need to charge the phone atleast 2 times in 1 day.. SO SAMSUNG PHONE FOR 900€ SHOULD HAVE FLAGSHIP SPECS dont you think ? Fix it pls because this is just scam.
4 REPLIES 4
Filip287
I just bought S24 phone and watch7 40mm like 2weeks ago. Both devices are draining battery so fast that I dont know if this is flagship mobile.. like HOW CAN IPHONE HAD BETTER BATTERY DRAIN WHEN THEY HAVE ABOUT 3000mah ???? My watch7 40mm for example are 100% at 10am and at 9pm they are like 10%(bluetooth, wifi and alwaysondisplay is OFF) and Im not doing on the watch nothing.. BUT I WOULD LIKE TO HAVE THIS FUCTIONS TURNED ON.
BandOfBrothers
Samsung Members Star ★★
Hello @Filip287 and may I extend a Warm Welcome to the Samsung Community Forum Section 👋
I'm sorry to hear your experiencing these battery drain issues with your phone and watch.
With the watch please clear it's cache files to see if that helps > https://www.reddit.com/r/GalaxyWatch/comments/1bo0nq2/reminder_to_wipe_cache_after_updating
https://www.samsung.com/uk/support/mobile-devices/reduced-battery-life-on-your-samsung-galaxy-watch.
If necessary you can reset the watch.
In regards to your phone it can take approximately 2 weeks + to have your phone complete the learning phase ,which is where the phone learns your usage habits.
The battery should then settle but obviously battery stats is a subjective topic as we all set up our phone's differently, and use different apps, and use them differently.
Poor Network signal can be battery draining as well can be regular sync schedules.
And it will take a few charges and discharges of the battery to reach optimum output.
In the phone's Settings under Device Care > Battery this will show you what is using the battery in the way if apps.
If an app is excessively using the battery then you can out the phone into Sleep and Deep Sleep Mode.
In the same Device Care Section there is an Optimisation tool you can run.
Another troubleshooting step is to Clear the Phone's System Partition Cache Files Section.
To do this which does nkt delete your own saved data >  Clear Cache Files from the phone's System Partition Section  > https://www.samsung.com/uk/support/mobile-devices/how-do-i-clear-the-cache-on-my-device/ You may need to insert your earphones or hook upto a powered On Laptop or use a Tv's USB Port to access the Clear Partition Section. This may help with lag or stutters as this clears the phone of old/unused or broken cache files.There is also a Repair Apps option in the Menu System too { Possibly excluding the s²⁴ Series of phone's }
If you perform a forum search you will find existing threads with some further help or guidence within in regards to battery saving tips.
If i can be of any further help please don't hesitate to ask  😎
Daily Driver > Samsung Galaxy s²⁵ Ultra 512Gb ~ Titanium Black.
I'm here to help. " This is the way. "
BandOfBrothers
I've asked for your two threads to be merged @Filip287
https://eu.community.samsung.com/t5/galaxy-s24-series/battery-drain-galaxy-s24-and-watch7-40mm.
Filip287
All the things you said I have done before and nothing helps
