Battery drain galaxy active watch 2
(Topic created on: 27-07-2020 07:49 PM)
GeertLeekens
Pioneer
All,
How can I see which app is draining my battery on the galaxy watch?
I believe it is Strava, without using it. But I'm not quite sure.
6 REPLIES 6
ARC20
Their most recent update, almost a month ago now, has ruined the app on the watch. My battery doesn't last half as long as it used to now.
richard49
I'm also having the same problem ; any ideas as to solve this problem as the watch is now unusable?
Rach77
Pathfinder
My watch active 2 sometimes drains down really fast. It can go from 80% battery to 15% in 2 hours. Today the battery was on 70% when I woke, I did an hours workout and about an hour after my watch vibrated to tell me tgat tge battery was low and told me to switch to battery saving mode. I out it on the charger as tge battery was 11% and left it for an hour and a half and when I checked on it the battery was only on 33%. I hope that my watch isn't having battery issues after less than a year!
tpatrick
So has anyone had any luck getting battery looked at by Samsung Support? Mine goes from 30-35% to switching off in about 15 minutes!
MrsVor
I have had this issue start a few days ago. This morning my battery went from 40% to 11% in ten minutes. Anyone find a solution?
Milkyblueeyes
Mine is the same. I went for a 4 hour walk at the weekend and it died and didnt record it. The battery is not fit for purpose at all....whats Samsung doing about it?
