Where to find the Tv guide
(Topic created on: 08-11-2022 08:00 PM)
Chris249
I have recently bought a QE50Q and for the life of me I cannot find the tv guide. I have found the channel list not a problem though.
Does anyone know how to get a full guide
5 REPLIES 5
JAMES4578
Samsung Members Star ★★
Hi @Chris249  You should be able to access the Tv guide  via the Smart Remote by pressing the centre of the Channel Up/Down Button.
KC1794
But why is not possible using the normal remote? Also does anyone know how to get the guide up and still see the program you're currently watching?
MrGloverLover
I have this issue on my new Q90B, the tv guide is not available unless I use a remote from another tv that actually has a tv guide button on it.  Pressing the centre of the channel up/down doesn't work
smithstar
Press AND HOLD the "channel list" button. You're welcome.
OakleyinVA
If it is a Samsung SolarCell Smart Remote, press and hold the right horizontal (channel) bar and a menu will appear on the screen and you can then arrow over to the guide view you want.
