Wall Mount Bolts
(Topic created on: 12-08-2023 02:06 PM)
Rob_Park
I have purchased a Samsung CU8000 55" TV, which I would like to mount to a wall. Please can you advise which VESA bolts I should use. I have numerous options for M4 bolts (12mm, 35mm), M6 bolts (12mm, 20mm, 35mm) or M8 bolts (16mm, 20mm, 30mm, 40mm, 50mm). Please advise the most suitable. Many thanks!
3 REPLIES 3
ChrisM
SuperStar
Hi @Rob_Park
The correct bolts for your TV are 4 x M8, 11-13mm. Hope this helps!
Luke1190
Hey Chris
Is it same bolt size for the.   UA50CU8000WXXY    50"?
Cheers, Luke
Flynnybhoy
Hi Chris I've just bought a Samsung UE55U7000KXXU 55inch TV, can you advise me on what bolts are needed?
