Go to solution Solved
Wall brackets for 75 inch #QN95A
(Topic created on: 07-07-2022 01:43 AM)
I Abaza
Hello everyone. I just bought Samsung neo QLED #QN95A 75 inch TV and I don’t know which brackets to buy to mount it on the wall. Does anyone have suggestions?!
Preferably also to mount a Samsung soundbar too (Q series).. thank you.
Obsydian
Samsung Members Star ★
I have the 55" of the QN95A and the matching Q900A soundbar.
I have not come across a combined wall tv/bar mount.
The slim wall mount is just for the TV
"Buy Slim Fit TV Wall Mount | WMN-A50E | Samsung UK" https://www.samsung.com/uk/tv-accessories/slim-fit-wall-mount-wmn-a50eb-xc/
2 Decades Samsung Ownership, If my response helps leave a Like and Accept as a Solution
DAILY: ZFold6, Watch Ultra, Fit3, CL Ace 2, BT-W6, 20,000 Power bank, Smart Tags
FAMILY: ZFlip5, ZFlip6, Watch6 Classic, Tab S8 Ultra, Tab S7 Plus, Buds Pro2, Buds3 Pro
OFFICE: Book2 Pro i7, M70A 32”, Logitech K700, MX Ego, M720 Triathlon, Pop, Jabra Evolve2
AV/GAMING: QN95A 50” TV, Q900A, SW900s, 8 Series TV, LG OLED, M70A 43”, Dell Inspiron G5
APPLIANCES: Jet 75 Vacuum, MC32 Oven, American Fridge, 8 Series TV, LG OLED
SPARES: ZFlip4, ZFlip3, Buds1 Pro, Buds2 Pro, Book2 Pro i5, Level Speaker
MAINTAIN: iPhone 14, iPad Air4, iPad Mini4, iPad Pro1 12.9, Watch6
5 REPLIES 5
Brian007
Navigator
Try eBay. Search under Samsung QN95A 75" wall bracket. Also Soundbar make and number. Also Google search for best prices as eBay isn't always the best prices.
I Abaza
Thank you for your reply Brian007. I’m looking for ppl who actually have the same TV mounted on the wall to hear about it. Thanks.
Obsydian
berginator
Pioneer
Hi abaza  can I ask what bracket did you eventually buy.
I Abaza
Hello there. I’ve bought this https://www.samsung.com/uk/tv-accessories/slim-fit-wall-mount-wmn-a50eb-xc/
from Samsung and they are amazing. Smooth fit on the wall. For the soundbar I’ve just put on the fireplace frame under the TV. I didn’t buy a separate brackets for it.
